I just updated to ArcGIS Pro 3.0.1 and I am having trouble with my Map Series. I use map series to create an as built based on a Work Order number. I am using an online layer to fill in data on my map series for the specific work order.
When I make a change to the online table it now has to process the update after every edit, and it also breaks my map series to where it shows every layer instead of filtering it down to the features that contain the work order number.
When I re-click the map series page for the work order number I'm on it will re-filter the layers. This is just adding a lot of time for creating and exporting these as builts.
Anyone have any ideas, or running into the same problem?
