I am putting together a file worker map that will be used to locate vans around the city. The vans have a day time and night time location (one asset #, two locations). In the hope of simplifying the field work I would like to create a multipoint feature that has day and night locations for each van. There is a attribute the field workers will use to mark the van found, which is the attribute the point is symbolize off of. I would like the data to allow a worker to choose a daytime van location, check the found box, and have the symbology for both the day and night point to change to the found symbol. I need to be able to symbolize the day and night locations differently so that field workers can easily identify day vs night locations, when I create the multipoint feature with two locations per asset I cant find a way to symbolize the day vs night location different for one asset. The goal is to have both day and night locations to be marked found for one asset if the field worker finds it during the day or at night.
I would appreciate any thoughts, thanks
