Hi All,
We are using
ArcGIS enterprise version: 10.9.1
ArcGIS Pro: V 3.0
Database: Postgres
We have enabled 'Branch version' on the feature dataset and published as "Feature services".
We are able to 'reconcile & post' using GP Tool in ArcGIS Pro.
By using the following ArcGIS API for Python code we are trying to automate the 'reconcile & post'.
# Name: Branch Version Reconcile & Post using the ArcGIS Python API
##----------------- Modules -------------------------------------------------------------
# import modules
import arcpy, datetime, requests, os
import arcgis.features
from arcgis.gis import GIS
import Config
# Disable warnings
requests.packages.urllib3.disable_warnings()
##----------------------------- Input & Derived Parameters ----------------------------------------
fs_url = arcpy.GetParameter(0)
version_name_txt = arcpy.GetParameter(1)
if fs_url.endswith("FeatureServer"):
base_url = os.path.dirname(fs_url)
else:
base_url = os.path.dirname(os.path.dirname(fs_url))
try:
start_time = datetime.datetime.now()
# Service URLs and GIS object
arcpy.AddMessage(f"connecting to {Config.portal_params.portal_url}...")
portal = GIS(
url=Config.portal_params.portal_url,
password=Config.portal_params.p_password,
username=Config.portal_params.p_username,
# Create a dict of service urls
services = ["FeatureServer", "VersionManagementServer"]
service_urls = {url: base_url + '/' + url for url in services}
# The Feature Server (service URL)
version_mgmt_svc = service_urls["VersionManagementServer"]
vms = arcgis.features._version.VersionManager(service_urls["VersionManagementServer"], portal)
arcpy.AddMessage(f'Version Management Service: {vms}')
# Check if the new version exists and get the fully qualified version name from the version's properties ('owner.versionName')
_version = [x for x in vms.all if version_name_txt in x.properties.versionName]
fq_version_name = _version[0].properties.versionName
arcpy.AddMessage(f'Fully qualified version name: {fq_version_name}')
# Reconcile the version with Default
with vms.get(fq_version_name, "edit") as version: # use "edit" to run start_editing
# Reconcile the version. Post if there are no conflicts detected.
try:
arcpy.AddMessage(f"Reconciling...")
reconcile_res = version.reconcile(end_with_conflict=True, with_post=True)
arcpy.AddMessage(f"Results of Reconcile & Post: {reconcile_res}")
if not reconcile_res:
arcpy.AddMessage(f"Reconciling the version {version.properties.versionName} failed.")
raise Exception(f"Reconciling the version {version.properties.versionName} failed.")
out_code = 1
arcpy.AddMessage(f"Reconciled and posted version: {version.properties.versionName}")
arcpy.AddMessage(f"Output Code: {reconcile_res}")
out_code = 0
arcpy.SetParameter(2, out_code)
arcpy.AddMessage(out_code)
end_time = datetime.datetime.now()
elapsed_time = end_time - start_time
arcpy.AddMessage(f"Dataset was locked for {elapsed_time.total_seconds()} secs")
except Exception as ex:
arcpy.AddMessage(f'Exception : {str(ex)}')
out_code = 1
arcpy.AddMessage(str(ex))
out_code = 1
When we execute this in ArcGIS Pro, we are getting error as "Version already in edit mode. Only one user can be editing a branch version."
Appreciate help on this please.
Sirish
