Has anyone printed a web map without using the ArcGIS Server print service? Is it possible? I am finding that the print service is too limiting. Is there a way to send HTML5 code to the map that is printed in the print service?
Brent Hoskisson
You could set the elements in CSS based on what you what to print like here:CSS Media Types and if you want to print to pdf you could use Apache FOP and convert a page into pdf using XSL-FO. There is also another way if you are using .NET by using iTextSharp with information here: Creating PDF Documents with ASP.NET and iTextSharp - 4GuysFromRolla.com
