i find many examples pretty useful but all written with amd / require-syntax.
so also the example with oauth login.
I got it running in the end, if you place the html in the assets-folder for the oauth-callback it is solved. Files in this folder are not going through the routing mechanism.
yeah thanks Andy, yesterday I had a look about what happened and the fact that my callback-html was never called did my realize that the routing is probably the issue, the popup is still my preferred way to do it so I have to dive deeper into that
Hi @Mannus_Etten I got it working okay using the inline login pattern. The sample you sent me wasn't working correctly because of how Angular routing works. I think you already suspected that because I saw you started to implement a router.
Here's the example app.component.ts (Angular 13, "@arcgis/core" version 4.24). You'll need to figure out all the CSS and routing, etc that happens after the log in process.
import { Component } from '@angular/core'; import OAuthInfo from "@arcgis/core/identity/OAuthInfo"; import esriId from "@arcgis/core/identity/IdentityManager"; import Portal from "@arcgis/core/portal/Portal"; import PortalQueryParams from "@arcgis/core/portal/PortalQueryParams"; @Component({ selector: 'app-root', templateUrl: './app.component.html', styleUrls: ['./app.component.css'] }) export class AppComponent { title = 'Test Login Page'; private info: OAuthInfo = new OAuthInfo({ // Swap this ID out with registered application ID appId: "YOUR_APPID_GOES_HERE", popup: false }); ngOnInit(): void { esriId.registerOAuthInfos([this.info]); esriId.checkSignInStatus(this.info.portalUrl + "/sharing") .then(() => { console.log("checkSignInStatus: User is signed in."); this.displayItems(); }) .catch(() => { console.error("checkSignInStatus: User not signed in.") }); } displayItems(): void { const portal = new Portal(); // Setting authMode to immediate signs the user in once loaded portal.authMode = "immediate"; // Once loaded, user is signed in portal.load().then(() => { // Create query parameters for the portal search const queryParams = new PortalQueryParams({ query: "owner:" + portal.user.username, sortField: "num-views", sortOrder: "desc", num: 20 }); console.log("User name: ", portal.user.username); // Query the items based on the queryParams created from portal above portal.queryItems(queryParams).then((q) => { console.log("Portal Query results:", q.results); }); }); } // Call from app.component.html page onLogin() { esriId.getCredential(this.info.portalUrl + "/sharing"); } // Call from app.component.html page onLogout() { esriId.destroyCredentials(); window.location.reload(); } }
And here is the example app.component.html:
<!-- app.component.html --> <div><button type="submit" (click)="onLogin()"><b>Login</b></button></div> <div><button type="submit" (click)="onLogout()"><b>Logout</b></button></div>
i have added you to the repo, thanks already for your help!
Hi @Werkwijze_R_beheerder are you working with @Mannus_Etten on the same application? It's a little unclear, and I wanted to make sure the original question got answered, if possible. Your question seems more related to a potential configuration issue.
hi Andy,
i prefer to have the popup-implementation. The popup shows, I can login and then i see in the popup the original angular-app... when i close the popup the console shows me that the login has been canceled 😞 I used the oauth-callback.html from the esri resources as callback url in the angular-app
@Mannus_Ettenthere are just a couple gotchas in Angular. If you aren't using an oauth popup, make sure you are adding the sign-in divs to your main component's html file. Also make sure to set the redirect_url when you register your app in your Portal (or ArcGIS Online), you may have to experiment with that a bit to get it right for your installation. Here are some example snippets:
@ViewChild('mapViewNode', { static: true }) private mapViewEl!: ElementRef; @ViewChild('anonymousPanel', { static: true }) private anonEl!: ElementRef; @ViewChild('personalizedPanel', {static: true}) private personalEl!: ElementRef; @ViewChild('signIn', {static: true}) private signInEl!: ElementRef; . . . this.anonEl.nativeElement.style.display = "none"; this.personalEl.nativeElement.style.display = "block"; this.signInEl.nativeElement.addEventListener("click", () => { // user will be redirected to OAuth Sign In page esriId.getCredential(info.portalUrl + "/sharing"); });
Check this video out. It's all in ESM and can be integrated into Angular projects.
https://community.esri.com/t5/arcgis-api-for-javascript-videos/identitymanager-in-the-arcgis-api-for-javascript/m-p/1191710#M21
Here's a blog post on the topic too.
https://odoe.net/blog/my-secret-arcgis-identity
