Hello
I am working with a point, line, and polygon file given to me by a client that they would like to use as the geographies for three different Survey123 forms that will be used to collect data related to each.
I am following the advice of @DougBrowning outlined in this post:
https://community.esri.com/t5/arcgis-survey123-questions/mapping-with-survey123-within-a-polygon-or-admin/td-p/836112
I have followed all the steps but am still confused. My confusion is outlined below.
When I publish one of the forms from Survey123 connect the Feature Service has a point feature layer (there is no geography question on the form so this I assume is the default) and the two related tables created from repeats in Survey123 Connect XLSForm. The default point file does inherit three of the questions from the XLSForm because I do not have those questions set up to be repeats, so they attach to the default point feature layer. When I made my .gdb in Catalog, the polygon feature that I am trying to use as my geography does not have these fields so when I try and link to the hosted feature layer and update the survey it will not allow it because it cannot find the originally created point files table.
Is it advisable to create repeats for all questions and to have the polygon only have a field that will relate to the three tables (two already created plus the new one)? In the two existing repeats I have a parentglobalid field that is populated from Field Maps from the polygon's GlobalID field. Also, can I not include the default point file in the new hosted feature layer?
Thanks for any clarification on this matter.
