The Layer to KML tool is not functioning as described in the documentation KML conversion—ArcGIS Pro | Documentation.
Once I add the folderPath field to the data I lose my popup configuration in the output KMZ and it will only show all of the attributes.
Before adding the folderPath field, the output KMZ popup would match the visible fields set in the attribute table.
I think this is a bug.
I am using ArcGIS Pro 2.9.3
