Hello All,
I'm currently using ArcPro 2.9.4. When I run enrichment from the 2021 Business Analyst database (stored locally) for any variables under the Behavioural category. I run into this error "Error 160253: The current operation cannot be undone.". This error only occurs when including variables from the behaviour category, but enrichment works fine for any of the other categories.
Does anyone know any potential solutions to bypass this error?
Thanks!
Brian
Hi Brian! Not sure if you're still having this issue but I just ran into the same exact thing; I have Pro 2.9.4, running BA Enrich Layer using a Behaviors variable and got the same error. Turns out I do not have "Esri Market Potential" variables licensed for my account which is why it kept failing. You can check your license and cross reference it with the data variable list to see which ones you have the proper licensing for. Cheers!
