Hi all,
I am trying to understand the behavior of ExtractMultiValuesToPoints when incorporated into an Arcgis tool.
I have used the function in an Arcpy standalone script, and it works just fine. However, after incorporating into a python tool, the stars have to be aligned just right for it to work. Included is a tool that I have created to extract values from a multiband raster into a new shapefile.
The issues are (1) I have to rename the bands because the tool generates new names not related to the raster bands, (2) if the shapefile is linked to the tool from a GIS workspace, the names aren't carried over, (3) rasters cannot be linked to from a GIS workspace and (4) ExtractMultiValuesToPoints has no option to preserve the original file (as far as I can tell). These are really just minor annoyances, so am wondering if I am somehow doing it wrong. Thanks for any information.
class Combine_labels_features(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "07 Combine labels and features"
self.description = "This tool combines the labels point shapefile (generated and QAQC'd) with the appropriate features file"
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
labels = arcpy.Parameter(
displayName="labels file",
name="labels",
datatype="GPFeatureLayer",
parameterType="Required",
direction="Input")
labels.filter.list = ["Point"]
features = arcpy.Parameter(
displayName="features (raster)",
name="features",
datatype= u'GPRasterLayer',
direction="Input")
outfile = arcpy.Parameter(
displayName="outfile",
name="outFile",
datatype="DEType",
direction="Output")
params = [labels,features,outfile]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
labels = parameters[0].valueAsText
infile = parameters[1].valueAsText
outfile = parameters[2].valueAsText
features = Raster(infile)
rasters = [] ### holder for raster predictors
nams = features.bandNames
names = ["B_" + str(i+1) for i in range(0,len(nams))]
for i in range(0,len(nams)):
print(nams[i])
tmplist = [infile + "\\" + nams[i],names[i]]
rasters.append(tmplist)
origNames = [field.name for field in arcpy.ListFields(labels)]
arcpy.sa.ExtractMultiValuesToPoints(labels,infile,"BILINEAR")
tmpfile = os.path.basename(tempfile.TemporaryFile().name)
arcpy.management.CopyFeatures(labels,tmpfile,'', None, None, None)
badNames = [field.name for field in arcpy.ListFields(tmpfile)]
badNames = [x for x in badNames if x not in origNames]
badNames.remove("OBJECTID")
BandKey = {badNames[i]:nams[i] for i in range(len(badNames))}
for key, value in BandKey.items():
print(key)
print(value)
arcpy.AlterField_management(tmpfile, key,value)
## add directly to initial labels. Should make copy if you want to preserve.
## ExtractMultiValuesToPoints is not behaving as it should. In Arcpy, the names from
## the original rasters carries through. Does not happen in the tool. Not sure why,
arcpy.management.CopyFeatures(tmpfile,outfile,'', None, None, None)
arcpy.Delete_management(tmpfile)
return
