I am new and I posted this question accidently in the wrong spot; sorry bad navigation. Couldn't find the delete post option so it is still there....
Hi Tyler,
Though there is no UI for this you can use ArcPy.mp (python) to create a thematic map series. There is a sample available at https://www.arcgis.com/home/item.html?id=eba53351ceb84b58b505dec5272e526c.
Hope this is what you're looking for.
Tom
Using this as a reference I managed to make a custom export script that seems to work. There is still a lot of setup time but at least I don't have to make a new map for each layer.
Wait I did find something that might help. In the ESRI fire book map solutions package there is a code for ReplaceLayers.py. Its a pre written code of what I was talking about before. Might be only suitable for file geodatabases but its a base for you to work with.
So its my understanding that a map book isn't suitable for your project if you want it to cycle through layers instead of layouts/extents. I've tried before too.
A Map Book Series can only interate through multiple layouts connected to the same map/data. It just cycles through map extents.
I recommend create a python script to cycle through changing your raster data sources and exporting a pdf map through each new raster layer. A place to start is connectionProperties. A close example (but Highly advance). Or maybe addDataFromPath method.
