I am working on the final parts of migrating to the utility network. I am struggling at finding the best design for meter boxes with multiple meters in them. I wanted to see if anybody has designed their meters to be contained in a boundary or structure junction? If so do you have a point for each meter or just one meter point with attributes indicating it is two? The method I've been trying (creating two meter points with a 'Y' service line design) has been leaving me with a ton of errors when enabling topology.
Theo
If you want to model every meter on the map, then you will need to ensure that the devices are not stacked on top of each other and that each one is connected to a service. In this case, I would recommend that you also use a meter box assembly to act as a container for your meters. This approach will take more time to draw and may clutter your map, but it will allow you to locate and trace your meters without any special tools.
If you don't want to model each individual meter, you could represent the meter box itself using a single meter (using an attribute to differentiate it from a single meter). In this case you would likely want to relate the device to a table that lists out the customers related to each meter. This keeps your map simpler, but means that you do have to do a few extra clicks to get from the meter to the customer information.
Hope that helps!
Robert,
In this example - "This keeps your map simpler, but means that you do have to do a few extra clicks to get from the meter to the customer information." Where is the customer information store? As attributes on waterdevice?
It is stored in a separate table. If you are integrating the data in that table with a bulk load from CIS nightly than you will want to leave it un-versioned and relate it to the device using your map). If the table is updated more selectively (with precise adds/delete/updates instead of a truncate/load) then you could consider versioning the table and creating a geodatabase relationship.
Regardless of the approach you use, you should consider using an Arcade expression to present the related info in a popup.
