Making a barrier to harvest water Greetings to all I have been trying for a long time to determine a water reservoir to collect water and determine the size of the lake that can be formed from this barrier or dam built on the riverbed. Are there any ideas on this topic or a video to help make a dam project and determine the size of the lake that may result from the construction of this dam? Thank you very much. Thanks Your friend Sabah Al Barwari.
Only an idea for a very simplified solution could be to insert the height of the dam into your digital elevation model and then run the fill tool of the spatial analyst? Maybe if you then use the minus tool between filled dem and the original dem you will hopefully get the resulting lake extend and the height of the water in each cell?
Or maybe this can help you?
https://learn.arcgis.com/de/projects/predict-floods-with-unit-hydrographs/
See my answer on GIS stack exchange here.
Greetings, I appreciate your wonderful response and the idea you presented as well as the link, I am working on it as well and will publish the result when it is finished. Greetings, and thank you very much, Mr. Johann Berer
Greetings, I appreciate your great response and the idea you presented as well as the link, I am working on it as well and will post the result when it is finished Greetings and thank you very much Mr. Duncan Hornby, I am working on these applications and your post and thank you
