Hi all!
I am currently creating a survey for manholes and conduits. Part of the questionnaire is a fillable Excel table where the user can manually input diameter, material, and depth, for the outlets and inlets (attached image). It would be similar to the table-list groups I created (in the survey123 image attached), the only difference being I want the user to manually input data. I tried looking it up, to no avail. I was wondering if anyone else has as solution. Thanks!
Ethan Fink
You cannot have an Excel table in S123. But there are a couple workarounds.
Option 1 (recommended):
Use a repeat. Inside the repeat, you will have 4 questions:
This allows you to collect all the data from your table. Your output report can easily be formatted like the image you attached.
Option 2:
Skip the repeat and just "hard code" the number input fields. You will still use all the fields described above, but instead of using a repeat, you will just have 4-5 copies of these fields. You could also use fixed-grid style to format the page like Excel.
This can be more complicated to set-up, and is far less dynamic that Option 1.
Thank you! I actually did exactly that, how you have it in option 1. Works like a charm! Thank you so much.
