HI
I am trying to begin a count at 50 rather than 1 and cant figure it out... likely because of the flu and massive headache I have
I know this should be very simple *sigh*
Can someone correct my code please...
Thank you in advance
Andreas
| type | name | label | hint | guidance_hint | appearance | required | required_message | readonly | default | calculation | constraint | constraint_message | relevant | choice_filter | repeat_count | media::audio | media::image | bind::type | bind::esri:fieldType | bind::esri:fieldLength | bind::esri:fieldAlias | body::esri:style | bind::esri:parameters | parameters | body::accept | body::esri:visible | body::esri:inputMask | label::language (xyz) | hint::language (xyz) | guidance_hint::language (xyz) | required_message::language (xyz) | body::accuracyThreshold | bind::esri:warning | bind::esri:warning_message | bind::saveIncomplete |
| hidden | CountSamples | Count Samples | | | hidden | | | | | count (${GetSampleLocation}) | | | | | | | | | esriFieldTypeInteger | | | | | | | | | | | | | | | | |
| text | NewCount | New Count | | | minimal | | | | | 50 + ${CountSamples} | | | | | | | | | esriFieldTypeInteger | | | | | | | | | | | | | | | | |
| text | SI_Name | <b>Sample Number</b> | | | minimal | | | | | if(${NewCount}< 10, "Wey2022" + ${IPADNo} + "000" + ${NewCount}, "Wey2022" + ${IPADNo} + "00" + ${NewCount}) | | | | | | | | | esriFieldTypeString | 20 | | | | | | | | | | | | | | | |
