I am working on a survey for a program where participants have an initial interview, then go through a series of check-in/follow-up sessions. After two sessions, they are eligible for an incentive voucher at each of the following sessions.
I have the session information set up in the survey as a repeat, where each session would be a new entry, and I’m trying to figure out a way to count the total number of vouchers given out over all the sessions. There is a relevant expression on the voucher question so that it doesn’t show up for the first two sessions, and I used a calculation coalesce(sum(${VoucherCount}),0) to get around the null values from that. It works in Connect but when I publish it to the web version, it doesn’t work anymore. If the repeat entries are all for sessions that have the voucher question, it works fine, but as soon as one of the repeat entries is for either session 1 or 2, the count of total number of vouchers given goes back to blank.
My guess to why it’s not working is because of a difference in how Connect and the web version interpret calculations, but I can’t figure out how to make it work. Any help would be much appreciated. The survey was designed in Connect and updated to version 3.15. I have attached a simplified version of the survey xls I made for testing the problem.
Thanks!
