When running Append Routes the Validation of route attributes failed and in the log that was written I found this message which was followed by a list of seven OIDs.
"Source data has curves. A list of offending OIDs is available below"
If curves are not supported in an LRS dataset is that documented somewhere?
Assuming that they are not supported is the best way to turn them into vertexed curves to copy their geometries out to and back from shapefile format?
