I have this script to export a Map Series to JPEG, based on ESRI's Map Series code sample #2, and it works well except when I try to export just a range of pages, not the whole set.
import arcpy, os, sys
p = arcpy.mp.ArcGISProject(r"G:\2xxx Projects\EA\2xxx-182 Oxford Road\ArcPro_Workspace\ArcPro_Workspace.aprx")
l = p.listLayouts("Stg1_results")[0]
print(l)
print(l.mapSeries)
if not l.mapSeries is None:
ms = l.mapSeries
print(ms.enabled)
if ms.enabled:
for pageNum in range(1, ms.pageCount + 1):
print("Exporting {0}".format(ms.pageRow.PageNumber))
pageName = ms.pageRow.PageNumber
l.exportToJPEG(os.path.join(r"Y:\2xxx Projects\EA\2xxx-182 Oxford Road\Output", "Stage 1 REV", f"S{ms.pageRow.PageNumber}"))
I have tried modifying the pageNum in range to show the pages I want (ex., pageNum in range(21,24,26,40) but I get a syntax error or invalid page numbers. Can anyone suggest how to modify this so I can extract just the pages I need?
Thanks.
