Working in ArcGIS Online with a feature service hosted on our ArcGIS Server Manager v 10.9.1. Using Map Viewer Forms for consumption in Field Maps app.
Field crews are using Field Maps to create Inspection Records in a table related to Water Meters. 1:M Meter:Inspections. Ultimately I would like to create a unique citation number for each inspection that records a violation of our new drought ordinance. But for now, I am testing to see if I can calculate a field in the Inspection table with the location ID of the water meter.
When I create the calculation in Arcade and hit the TEST button, the results give me a single string with the Loc_ID which is what I want to populate the attribute in the Inspections table. See attached image.
When I use a simpler calculation, such as calculating a date field using Now(), it populates correctly in Field Maps.
There is an Expression compatability notice when I create a new calculation expression: "Calculated expressions that use Feature Sets are not supported in Map Viewer." I am assuming that this is what I am running up against.
Is anyone having success doing this, perhaps in a different way?
Can any ESRI folks confirm that this is functionality that is not working in Field Maps?
Thanks in advance,
Mary Anne
