import QtQuick 2.0
import QtQuick.Window 2.0
import QtQuick.Controls 2.2
import QtPositioning 5.12
import QtLocation 5.12
import Esri.ArcGISRuntime 100.14
Item
signal transmetreClique (var lat, var log, var changer, var zoom)
signal transmettreCliqueSuppression(var lat, var log, var zoom)
signal clavierToucheSuppr()
signal undo();
signal redo();
MapView
anchors.fill: parent
// set focus to enable keyboard navigation
focus: true
property bool changer : false
property int item;
property bool animer : false
property int tot : 1
property bool buttonvalue : false;
property var polygon_contour_obj : null;
property var polygon_buffer_obj : null;
property var polygon_contour : null;
property var polygon_buffer : null;
property var listPolyline : [];
property var listPolygonContour : [];
Component.onCompleted: {
// Set the focus on MapView to initially enable keyboard navigation
forceActiveFocus();
// add a map to the mapview
Map {
// add the ArcGISTopographic basemap to the map
initBasemapStyle: Enums.BasemapStyleArcGISImagery
initialViewpoint: viewpoint
GraphicsOverlay {
ViewpointCenter {
// Specify the center Point
center: Point {
x: 2.3522219
y: 48.856614
spatialReference: SpatialReference {wkid: 4326}
targetScale: 50000000.0
onMouseClicked: { //on MapView
const spatialReference = ArcGISRuntimeEnvironment.createObject("SpatialReference",{wkid: 4326});
const projectedPoint = GeometryEngine.project(mouse.mapPoint, spatialReference);
console.log(projectedPoint.x,projectedPoint.y,map.mapScale );
if (mouse.button == Qt.LeftButton && mouse.objectName != 'bouton')
transmetreClique( projectedPoint.y,projectedPoint.x,map.changer, map.mapScale)
else
transmettreCliqueSuppression( projectedPoint.y, projectedPoint.x, map.mapScale);
map.changer = false
Keys.onPressed: {
if( event.key === Qt.Key_Escape)
//console.log("ok");
map.animer=false;
animation.running=false
map.changer = false
if(map.listPolygonContour[map.item].length > 3)
map.listPolygonContour[map.item][2].visible =true
else if (event.key === Qt.Key_Delete && map.changer)
map.changer = false
Button {
width: 80
height: 30
x: qmlMap.width-width-10
y: 10
font.pointSize: 16;
background: Rectangle {
radius: 5
property bool buttonvalue : true;
//color:"yellow"
visible: true
text: ">"
flat : false
onPressed: {
fondUndo.opacity = .80
redo()
onReleased:
fondUndo.opacity = 1
Button {
width: 80
height: 30
x: qmlMap.width-width-20-buttonUndo.width
y: 10
font.pointSize: 16;
radius: 5
//color:"yellow"
visible: true
text: "<"
flat : false
onPressed: {
fondRedo.opacity = .80
undo()
onReleased:
fondRedo.opacity = 1
Point {
x : 0
y : 0
PolygonBuilder {
PolygonBuilder {
SimpleFillSymbol {
style: Enums.SimpleFillSymbolStyleNull
color: "yellow"
SimpleLineSymbol {
style: Enums.SimpleLineSymbolStyleSolid
color: "red"
width: 1
antiAlias: true
SimpleFillSymbol {
color: "yellow"
SimpleLineSymbol {
color: "blue"
width: 1
antiAlias: true
SimpleLineSymbol {
color: "yellow"
width: 4
antiAlias: true
PictureMarkerSymbol {
url : "../ressource/marqueur_rouge.png"
width : 60
height : 60
url : "../ressource/marqueur_bleu.png"
width : 60
height : 60
url : "../ressource/marqueur_jaune.png"
width : 20
height : 20
PointBuilder {
spatialReference: SpatialReference { wkid: 4326 }
function createGraphic(geometry, symbol) {
console.log("create graphic debut")
//I suppose, the line create the crash (beacause ofen the crash, the line "create graphic debut" it's display
const graphic = ArcGISRuntimeEnvironment.createObject("Graphic");
console.log("1")
graphic.geometry = geometry;
console.log("2")
graphic.symbol = symbol;
console.log("create graphic fin")
return graphic;
function reset()
console.log("reset")
map.changer = false;
map.animer=false;
function viderPoint (changeParcelle)
console.log("vider")
graphicsOverlay.graphics.clear()
if (map.polygon_buffer && map.polygon_contour)
map.polygon_buffer.destroy()
map.polygon_contour.destroy()
map.listPolygonContour = [];
map.listPolyline = []
map.polygon_contour = Qt.createQmlObject('
import QtQuick 2.0
PolygonBuilder {
}',qmlMap)
//console.log(map.polygon_contour)
map.polygon_buffer = Qt.createQmlObject('
import QtQuick 2.0
PolygonBuilder {
}',qmlMap, "dynamicSnippet1" );
if (changeParcelle)
ptBuilder.setXY(2.3522219,48.856614);
//ptBuilder.setXY(0,0);
map.setViewpointCenterAndScale(ptBuilder.geometry, 50000000.0);
function modifPoint(lat,log)
console.log("modif pooint")
console.log("change : " + lat +" "+ log)
map.changer = false
/*map.mapItems[map.item-1].opacity= 1
map.mapItems[map.item-1].coordinate = QtPositioning.coordinate(lat, log)*/
function addPointParcelle(lat, log,val)
console.log("debut add parcelle")
if (map.polygon_contour_obj)
var index = graphicsOverlay.graphics.indexOf(map.polygon_contour_obj);
if (index !== -1)
graphicsOverlay.graphics.removeOne(map.polygon_contour_obj)
map.polygon_contour.addPointXY(log,lat);
map.polygon_contour_obj = createGraphic(map.polygon_contour.geometry, polygon_fill_symbol_buffer_contour);
graphicsOverlay.graphics.append(map.polygon_contour_obj);
//lat = lat +projectedPoint.y
var marqueuradd = Qt.createQmlObject('
import QtQuick 2.0
Point {
x: '+log+'
y: '+lat+'
}',qmlMap)
var point_graphic = createGraphic(marqueuradd, pictureMarkerSymbolBorder);
graphicsOverlay.graphics.append(point_graphic);
map.listPolygonContour.push([log,lat,point_graphic])
map.tot = map.tot + 1
console.log("fin add parcelle")
function addPointParcelleBufferiser(lat, log)
console.log("debut add buffer")
if (map.polygon_buffer_obj)
var index = graphicsOverlay.graphics.indexOf(map.polygon_buffer_obj);
if (index !== -1)
graphicsOverlay.graphics.removeOne(map.polygon_buffer_obj)
map.polygon_buffer.addPointXY(log,lat);
map.polygon_buffer_obj = createGraphic(map.polygon_buffer.geometry, polygon_fill_symbol_buffer);
graphicsOverlay.graphics.append(map.polygon_buffer_obj);
//polygoneBufferiser.addCoordinate(QtPositioning.coordinate(lat,log))
//map.addMapItem(polygoneBufferiser)
import QtQuick 2.0
Point {
x: '+log+'
y: '+lat+'
}',qmlMap)
var point_graphic = createGraphic(marqueuradd, pictureMarkerSymbolBuffer);
console.log("fin add buffer")
function setCenter(lat,log)
console.log("cset center")
ptBuilder.setXY(lat, log);
map.setViewpointCenterAndScale(ptBuilder.geometry, 10000.0);
function clearParcours()
console.log("clear parcours")
while (map.listPolyline.length > 0)
var elem = map.listPolyline.pop()
graphicsOverlay.graphics.removeOne(elem)
function addLine (lat1,log1, lat2,log2)
console.log("add line")
console.log ("lat1 : " + lat1 +", log 1 : "+ log1 + ", lat2 : "+lat2 + ",log 2 : " + log2);
if(map.tot > 9)
map.tot = 0;
else
map.tot++;
const line = {"paths":[[[log1,lat1],[log2,lat2]]],"spatialReference":{"wkid":4326}}
const line1 = ArcGISRuntimeEnvironment.createObject("Polyline", {"json": line });
const line_graphic = createGraphic(line1, line_symbol_path);
console.log(line_graphic)
map.listPolyline.push(line_graphic)
graphicsOverlay.graphics.append(line_graphic);
function faireClignoterPoint(lat,log)
console.log("cligbotter")
console.log(" rechercher : lat " + lat + "log " + log);
map.item = 0;
var trouver = false
while (map.listPolygonContour.length > map.item && !trouver)
console.log("lat " + map.listPolygonContour[map.item][0] + "log " + map.listPolygonContour[map.item][1]);
//console.log("val : "+ map.mapItems[i].coordinate.latitude + ' ' + map.mapItems[i].coordinate.longitude );
if (map.listPolygonContour[map.item][1] === lat && map.listPolygonContour[map.item ][0] === log)
console.log("trouver",map.listPolygonContour[map.item][2])
trouver = true;
map.changer = true;
console.log(map.listPolygonContour[map.item][2].visible )
//map.polygon_contour_obj[0].opacity = 2
animation1.target = map.listPolygonContour[map.item][2];
animation2.target = map.listPolygonContour[map.item][2];
animation3.target = map.listPolygonContour[map.item][2];
animation4.target = map.listPolygonContour[map.item][2];
//console.log("activer suite");
animation.running=true
// console.log("activer fin");
else
map.item = map.item + 1;
function pointDebut(lat,log)
console.log("point debut")
import QtQuick 2.0
Point {
x: '+log+'
y: '+lat+'
}',qmlMap)
var point_graphic = createGraphic(marqueuradd, pictureMarkerSymbolStarter);
function afficherPointDebut(lat,log)
console.log("cpoint debut bis")
import QtQuick 2.0
Point {
x: '+log+'
y: '+lat+'
}',qmlMap)
function subButton()
console.log("sub bouton")
buttonRedo.destroy();
buttonUndo.destroy();
SequentialAnimation{
running: false
loops: Animation.Infinite
PropertyAnimation {
//target: rect
to:0
properties: "visible"
duration: 100
PropertyAnimation {
//target: rect
to:0
duration: 300
PropertyAnimation {
//target: rect
to:1
duration: 100
PropertyAnimation {
//target: rect
to:1
duration: 300
