I did not find information on how I can make a form in version 3.40, but what I need, a form where I can insert the longitude and latitude where it shows it on the map once inserted.
For the time being, I add the points with a button:
Reference: Sample graphics add
* The function is called initToolbar() and it creates a new Draw object called tb. The tb object is
* then used to create a new event listener called "draw-end" which calls the addGraphic() function.
* The function then creates a new event listener called "click" which listens for clicks on the
* "info" div. If the click is on the "info" div, the function returns. If the click is on a button,
* the function gets the id of the button and sets the tool variable to the id of the button. The map
* navigation is then disabled and the tb object is activated with the tool variable.
* @returns the value of the variable tb.
function initToolbar() {
tb = new Draw(map);
tb.on("draw-end", addGraphic);
// event delegation so a click handler is not
// needed for each individual button
on(dom.byId("info"), "click", function (evt) {
if (evt.target.id === "info") {
return;
var tool = evt.target.id.toLowerCase();
map.disableMapNavigation();
tb.activate(tool);
function addGraphic(evt) {
//deactivate the toolbar and clear existing graphics
tb.deactivate();
map.enableMapNavigation();
// figure out which symbol to use
var symbol;
if (evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
symbol = markerSymbol;
} else {
symbol = fillSymbol;
var graphic = new Graphic(evt.geometry, symbol, {Latitude: evt.geometry.getLatitude(), Longitude: evt.geometry.getLongitude()});
var features = [graphic];
featureLayer.applyEdits(features, null, null);
map.infoWindow.setTitle("Localización");
map.infoWindow.setContent("Latitud: "+evt.geometry.getLatitude()+ "Longitud: "+evt.geometry.getLongitude());
map.infoWindow.show(graphic.geometry, map.getInfoWindowAnchor(graphic.geometry));
map.centerAndZoom(graphic.geometry, 3);
// map.graphics.add(new Graphic(evt.geometry, symbol));
} But I can't figure out how to make a form.
I hope you can help me, thank you.
