I survey open pits in mining and it would be helpful if the camera angle on vertical flight could be adjusted eg. 30°- 45° so I could capture the benches between levels on a single flight. Currently I need to combine the vertical flight with an area survey when processing to create the model of the pit walls. The average wall angle in our pits is 30°. This would assist with wall monitoring in open pit mining.
Hi @DanielHolsgrove , Camera angles are defined automatically based on the flight and region of interest parameters you input. Have you tried adjusting the slope of your vertical scan?
For a wall angled at 30º, you shouldn't need to add an Area Survey. Something like this: Vertical Scan - 30º slope
Site Scan Flight also allows you to define a variable slope if you'd like. If setting a slope angle doesn't help, please share images showing what your challenge is, I may not be visualizing it correctly.Regards,Nico
Connectez-vous pour publier, suivre le contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
