Good Morning, ( using ArcGIS Pro2.9.2)
I am working with Survey123 Data that was originally a hosted feature service in an ArcGIS Online organizational account. A replica was created, & downloaded so it is no longer hosted. Data management and analysis is being done in ArcGIS pro, with the goal to republish the data in a local server and Portal for use in maps and dashboards.
This data has a polygon feature class with attachments, and a related table with attachments. The attachments are photos stored as BLOBs
The issue->
Due to a series of data processing, the REL_GLOBALID in the attachments for the photos (stored as BLOBs) of a related table changed. Though maybe not the best way, I was hoping to rectify the data in the attachments table and then join (join field) the BLOB data based on the attachment name. However, the join field does not allow you to select the DATA field in the join field tool. It is the only one that cannot be joined.
Any help with this (even if you tell me an entirely different way to go about it), would be much appreciated!
Cheers,
Jessica
