Hello everyone!
We have moved our subcription of ArcGIS Online from US-Server to EU-Server. The bad is, that we have to get a new subcription and account for this. As a result of this we have to clone all items from the old account to the new one.
I used this technical support article https://support.esri.com/en/technical-article/000022252
Unfortunately I get an error!
My simple code is:
from arcgis.gis import GIS
gis1 = GIS("https://arcgis.com", "", "")
gis2 = GIS("https://arcgis.com", "", "")
num_items = 250
items = gis1.content.search(query='owner:', max_items=num_items)
items
gis2.content.clone_items(items)I used items and num_items, because only in this way, all items were listed, otherwise there were only 13 items showed.
This is the error I get:
AttributeError Traceback (most recent call last)
/tmp/ipykernel_129/2581389438.py in <module>
8 items
9
---> 10 gis2.content.clone_items(items)
/opt/conda/lib/python3.7/site-packages/arcgis/gis/__init__.py in clone_items(self, items, folder, item_extent, use_org_basemap, copy_data, copy_global_ids, search_existing_items, item_mapping, group_mapping, owner, preserve_item_id)
6728 group_mapping,
6729 owner_name,
-> 6730 preserve_item_id=preserve_item_id,
6731 )
6732 return deep_cloner.clone()
/opt/conda/lib/python3.7/site-packages/arcgis/_impl/common/_clone.py in __init__(self, target, items, folder, item_extent, service_extent, use_org_basemap, copy_data, copy_global_ids, search_existing_items, item_mapping, group_mapping, owner, preserve_item_id)
106 self._temp_dir = tempfile.TemporaryDirectory()
107 # parse the config and get values
--> 108 self._create_graph()
109 self._cloned_items = []
110
/opt/conda/lib/python3.7/site-packages/arcgis/_impl/common/_clone.py in _create_graph(self)
118 user = self.target.users.me
119 # Get the definitions associated with the item
--> 120 self._get_item_definitions(item)
121
122 # Test if the user has the correct privileges to create the items requested
/opt/conda/lib/python3.7/site-packages/arcgis/_impl/common/_clone.py in _get_item_definitions(self, item)
326 except RuntimeError:
327 raise
--> 328 item_definition.add_child(self._get_item_definitions(webmap))
329 for layer_id in layer_ids:
330 try:
243
244 item_definition = None
--> 245 source = item._gis
246
247 # Check if the item definition has already been added to the collection of item definitions
AttributeError: 'NoneType' object has no attribute '_gis'
What I am doing wrong here?
Thanks!
