I extracted the ArcGISPro.msi MSI file from the ArcGISPro_29_179927.exe installer and set up the Application installation in Microsoft Endpoint Configuration Manager as I have done in the past without issue. I set it to install silently and it runs into an 0x643(1603) error. I changed the installer to run normally so I could see the error, and I got a message stating that I must accept the EULA.
I checked the switches at Install ArcGIS Pro silently—ArcGIS Pro | Documentation and added the ACCEPTEULA=YES as it instructed. I ran the installer and it still requests I accept the EULA. I want to set this up to install silently and without user input. Below is my current SCCM Application script:
msiexec /i "ArcGISPro.msi" ACCEPTEULA=YES ALLUSERS=1 INSTALLDIR="C:\MyArcGISPro\" ADDLOCAL=Pro /qb
This was taken directly from the ESRI documentation. I did move the ACCEPTEULA=YES up, but that is the only change I made and it didn't work as written in the documentation anyway. I set the Application to install only to System, not to user.
Thanks.
