I have a required field in my survey that is populated using a select one question and some logic that allows a user to enter a value if the correct value is not in the choice list. When someone goes into the survey to edit the record the existing value doesn't populate, so the user has to re-enter the information. I have tried setting the default value as the field value and also tried to set the value using the calculate field with calculationMode=always, but neither approach works. I thought the problem might be a field type mis-match, so I added a field to just view the existing value, and tried both the default and calculation methods, but that doesn't work either. I'm sure there's some simple fix for this, but I just don't see it. My code is attached.
I'm using Survey123 Connect version 3.13.234 and the XLS Form Template - Advanced; version 3.13 rev date 25 August 2021.
