Hello All,
I am new to Arcade Data Expressions and I would like to return a Feature Set that contains all of the "Fire Numbers" and the corresponding "District" (polygon) that it falls within. I started off with the code in the below link and tried to modify it a little to make it work for my situation. Mainly, I added an additional sub "for-loop" to iterate through the points and for each point determine the district it falls within and put that into an array and finally a dictionary.
https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/SpatialAggregation.md
The Data Expression will be used within a Category Selector so I can filter the fire numbers out that only fall within a specific district (a district selector would filter out this data expression feature set to show only relevant fire numbers )
I am not able to get this to work and I am unsure what to try next. Can anyone potentially guide me in the right direction or maybe show another approach? Any help is very much appreciated!
// Portal
var portal = Portal('https://governmentofbc.maps.arcgis.com/');
// Create FeatureSet for polygons
var poly_fs = FeatureSetByPortalItem(
portal,
'5ccd439dd835451aa304468ebdce0427',
58,
'ORG_UNIT'
true
// Create Featureset for points
var pt_fs = FeatureSetByPortalItem(
portal,
'397a1defe7f04c2b8ef6511f6c087dbf',
0,
'FIRE_NUMBER'
true
// Create empty feature array and feat object for output
var features = [];
var feat;
// Iterate over fire points
for (var pt in pt_fs) {
// Iterate over districts
for (var poly in poly_fs) {
// Filter points by polygon
var pts = Contains(poly, pt);
// Create feature with aggregated values
feat = {
'attributes': {
'district': poly['ORG_UNIT'],
'fire': pt['FIRE_NUMBER']
// Push feature into array
Push(features, feat);
// Create dict for output FeatureSet
var out_dict = {
'fields': [
{'name': 'district', 'alias': 'Districts', 'type': 'esriFieldTypeString'},
{'name': 'fire', 'alias': 'Fire Number', 'type': 'esriFieldTypeString'}
'geometryType': '',
'features': features
// Convert dictionary to feature set.
return FeatureSet(Text(out_dict));
