I can't find a way to solve this issue. I republished this survey many times but no luck.
The first time that I created the survey I had this error, spent 3 hrs and the next day it fixed by itself apparently. After that I had to take multiple amendments to the survey and I wasn't able to generate the report for it anymore.
It gives this error both with a custom template and a default one.
An error occurred while generating reports. Hide details
An error occurred when rendering by the report engine. Failed to print map for
${Observation_Points}. Error: Failed to print map: {"name":"request:server","message":"Error","details":{"url":"
https://services6.arcgis.com/kjjvcdcJGTe/arcgis/rest/services/service_fa7ae8f9xxxxxxxxx/FeatureServer/1/query","requestOptions":{"query":{"f":"json","returnExtentOnly":true,"returnCountOnly":true,"objectIds":"2","spatialRel":"esriSpatialRelIntersects"},"responseType":"json"},"ssl":false,"httpStatus":400,"messages":["This operation is not supported."],"raw":{"code":400,"message":"","details":["This operation is not supported."]}}}
Note that I changed the service url to post it.
Any help will be dramatically appreciated
