Hi everybody,
I have to write an console application, that creates an lyrx-File of a wms-service.
I should be able to create a Layer using the Layer Factory, but it needs a map.
So I try to Create an empty Map first.
When I do, I get an Exception:
System.NullReferenceException
HResult = 0x80004003
Nachricht = Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
Quelle = ArcGIS.Desktop.Mapping
Stapelüberwachung:
at ArcGIS.Desktop.Mapping.MapFactory.<>c__DisplayClass5_0.<CreateMap>b__0()
at ArcGIS.Desktop.Internal.Mapping.Utilities.MakeBasicServiceCall[T](Func`1 serviceCall)
at ArcGIS.Desktop.Mapping.MapFactory.CreateMap(String name, MapType mapType, MapViewingMode defaultViewingMode, Basemap basemap)
Unfortunately I have no idea what my error is.
Thank you, for reading
Andreas Ruloffs
using ArcGIS.Core.CIM;
using ArcGIS.Core.Hosting;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Mapping;
using Microsoft.Win32;
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Reflection;
using System.Text;
using System.Threading.Tasks;
namespace ProCoreHost3
class Program
//[STAThread] must be present on the Application entry point
[STAThread]
static void Main(string[] args)
AppDomain currentDomain = AppDomain.CurrentDomain;
currentDomain.AssemblyResolve += new ResolveEventHandler(ResolveProAssemblyPath);
if (args.Length != 3)
Console.Out.WriteLine("usage: CreateWMSLyr <wmsurl> <visibleLayer seperated by commas> <outputfile name");
Environment.Exit(1);
String wmsURL = args[0];
String visibleLayerStr = args[1];
String outFile = args[2];
String[] visibleLayer = visibleLayerStr.Split(new char[] { ',' });
MainAsync(wmsURL, visibleLayer, outFile).GetAwaiter().GetResult();
static async Task MainAsync(String wmsURL, String[] visibleLayer, String outFile)
//Call Host.Initialize before constructing any objects from ArcGIS.Core
try
Host.Initialize();
catch (Exception e)
// Error (missing installation, no license, 64 bit mismatch, etc.)
Console.WriteLine(string.Format("Initialization failed: {0}", e.Message));
return;
Map map = MapFactory.Instance.CreateMap("test", MapType.Map, MapViewingMode.Map, Basemap.None);
CIMInternetServerConnection serverConnection = new CIMInternetServerConnection
URL = wmsURL
CIMWMSServiceConnection connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
Layer layer = LayerFactory.Instance.CreateLayer(connection, MapView.Active.Map);
LayerDocument layerdocument = new LayerDocument(layer);
layerdocument.Save(outFile);
static Assembly ResolveProAssemblyPath(object sender, ResolveEventArgs args)
string folderPath = @"C:\Program Files\ArcGIS\Pro\bin"; //Get this from registry
string assemblyPath = Path.Combine(folderPath, new AssemblyName(args.Name).Name + ".dll");
if (!File.Exists(assemblyPath)) return null;
Assembly assembly = Assembly.LoadFrom(assemblyPath);
return assembly;
