I have a simple calculation in a repeat that is not working. I had this setup and it was working great, but now to get it to work in the mobile app, I have to delete the first repeat record and then add a new record for the calculation to work. Below are the fields and calculation from the XLS form.
| type | name | required | readonly | calculation |
| decimal | CU_MIX | yes | | |
| decimal | CU_TOTALGAL | yes | | |
| decimal | CU_AMOUNT | yes | yes | (${CU_MIX}*0.01)*${CU_TOTALGAL} |
This is what the mobile app looks like when the repeat record loads and numbers are entered into the CU_MIX field (% Conc. of Mix) and the CU_TOTGAL (Total Gallons of Mix Used) field. The calculated field CU_AMOUNT (Amount of Chemical Applied) is blank.
But after deleting the first repeat record and adding a new record, the calculation works perfectly:
I'm running version 3.14.237 in the mobile app and Version 3.14.256 in Connect. This calculation was working without issues a few weeks ago when I first set it up, but now it's not working. Both the mobile app and Connect were upgraded between then and now, could that be associated with this issue? Or do I have the calculation setup incorrectly in the repeat?
Thank you for the help.
Nick
