I'm trying to populate attribute values using both the Attributes pane and the field calculator in ArcGIS Pro 2.8.4. Both methods only set/calculate the cell values for 40 records at a time even though I have many more than that (sometimes all records) selected. The Extent environment setting is set at Default, so it isn't limiting anything. I have to run the calculation, re-select records that didn't get populated and run the calculation again, etc. Only 40 records are being populated each time. The feature class is in a SQL Server enterprise geodatabase.
