I would like to be able to connect to a service with branch versioning enabled. Then get a list of available versions and set that version so that all subsequent operations are completed use data from that version. Specifically I would need read access as there is no current requirement for edit access.
Branch Versioning is an important functionality. Thanks for the detailed description of how you plan to use it.
Hi @JimmyBowden,
The ArcGIS for AutoCAD team implemented branch versioning as part of the version 430 release. Here is a blog post that gives an overview.
You can now add branch version enabled web feature layers to your drawings. You can also create and/or change to named branch versions for layers of interest. Read/edit access is determined in accordance with your Esri named user account and level of access to a given web feature layer. Additional technical details are here.
Thanks again for posting this idea and for providing details of your planned usage of branch versioning.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
