I need help with coordinate systems in ArcGIS Pro Version 2.6.
I tried to get Feature Class layers from gridded climate data of the DWD in ASC format using the tool 3D ASCII in Feature Class after I imported the projected coordinate system from DWD -> https://opendata.dwd.de/climate_environment/CDC/grids_germany/multi_annual/air_temperature_mean/BESCHREIBUNG_gridsgermany_multi_annual_air_temperature_mean_8110_de.pdf
It´s DHDN_3_Degree_Gauss_Zone_3
ASC Data is from -> https://opendata.dwd.de/climate_environment/CDC/grids_germany/multi_annual/air_temperature_mean/
The so done layers all ended up in the ocean southwest from Africa wich is absolutely incorrect.
I also tried to change separator from point to comma; that doesn´t change anything.
Tried different coordinate systems... all layers ended up in the ocean but they should cover Germany!
I have no idea what else could help and really hope to find a solution here.
