I am trying to set up a tool to allow the user to click a graphic element in the graphics layer and move it around the map. Moving the graphic is extremely slow and I'm wondering if there is a better way to do what I'm trying to do.
internal class MoveGraphics : MapTool
private int? movingGraphic = null;
private IReadOnlyList<GraphicElement> currentElements;
public MoveGraphics()
IsSketchTool = false;
SketchType = SketchGeometryType.Point;
SketchOutputMode = SketchOutputMode.Map;
protected override Task OnToolActivateAsync(bool active)
return base.OnToolActivateAsync(active);
protected override void OnToolMouseUp(MapViewMouseButtonEventArgs e)
base.OnToolMouseUp(e);
protected override void OnToolMouseDown(MapViewMouseButtonEventArgs e)
e.Handled = true;
protected override Task HandleMouseDownAsync(MapViewMouseButtonEventArgs e)
return QueuedTask.Run(() =>
var mp = MapView.Active.ClientToMap(e.ClientPoint);
currentElements = Module1.Current.SelectedGraphicsLayerTOC.GetElementsAsFlattenedList();
var coordinates = currentElements.Select(graphic => graphic.GetAnchorPoint());
var multiPoint = MultipointBuilder.CreateMultipoint(coordinates, Module1.Current.SelectedGraphicsLayerTOC.GetSpatialReference());
var proximityResult = GeometryEngine.Instance.NearestVertex(multiPoint, mp);
if (proximityResult.Distance < 0.0004)
movingGraphic = proximityResult.PointIndex;
protected override void OnToolMouseMove(MapViewMouseEventArgs e)
if (!movingGraphic.HasValue) return;
var element = currentElements[movingGraphic.Value];
var graphic = element.GetGraphic() as CIMPointGraphic;
graphic.Location = mp;
element.SetGraphic(graphic);
} When the user clicks on the map, I determine which point was closest to the click using the GeometryEngine's NearestVertex method. When the mouse is moved if a graphic is selected, I get the GraphicElement object, I get the MapPoint of the mouse, I set the Location property of the graphic to the new MapPoint, and update the graphic of the element using SetGraphic. I have also tried using the SetAnchorPoint method as well. Both of these methods have been very slow and take a few seconds to move the point to the new mouse position. Does anyone have a better/faster way of moving point graphics?
