Hello, I am trying to run the Weighted Sum tool and keep getting this error message:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (Weighted Sum).
I'm using ArcGIS Pro 2.8.3 and Weighted Sum tool in Model Builder. Inputs are 5 raster datasets with Field assigned correctly and weights assigned.
Input files are saved on OneDrive; I suspect this may be the issue. I pause OneDrive syncing while running Arc Pro but when I try to copy the files to a local location to see if that helps, I run into other issues.
