I have created a survey with quiet a lot of questions. In survey123 connect there are 858 fields in my survey123. The issue I am having is that after I publish the survey and try to submit a test record (either on the computer or through mobile app) I get a error message "database error has occurred". I have done some research and I am sure that the feature service is correct and works. The survey has two parts and I have tried to split the survey into two separate surveys, when I do this and republish separately, I get no errors when submitting. I have found that a survey should be able to handle 1,024 columns (including system fields). Everything works well on survey123 connect and everything publishes without error, it is only at submission that I get any errors.
Has anyone had this issue before or found a "limit" to survey123 questions? For reference I am using Survey123 Connect 3.13.251, and publishing to my enterprise account and I am on enterprise 10.8.1
