I want to run Attribute Rule testing in a file geodatabase so that way I don't have to boot all my users from the system to run testing. I want to be able to export my Utility Network so I can run rules based off related records. Anyone have suggestions on how to do so?
This capability was added in ArcGIS Pro 2.9. Here is the text from the What's new in ArcGIS Pro 2.9:
This was added in ArcGIS Pro 2.9. Here is the text from the What's new in ArcGIS Pro 2.9:
Hi sjet1010,
You could export the asset package (including your data) using the "Export Asset Package" geoprocessing tool and deploy the package to a FGDB. When working with attribute rule in FGDB You have to keep in mind that some Arcade scripts could work in the FGDB but won't have the same behavior/result in the Enterprise Geodatabase.
Another alternative is to create a testing environment by copying your operational Enterprise Geodatabase to a different instance of your DBMS, this option will allow you to test your attribute rules in a similar environment as your operational data.
Connectez-vous pour publier, suivre le contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
