Hi Folks,
I am well aware of the powers of the WAB dev edition. But due to organiizational reasons I would like to avoid using DEV edition.
Yet I ask myself: can I change the style of a theme in the build in WAB in Enterprise?
I was following this tutorial here, restarted portal but none of the changes were applied:
Create a new style for a theme—ArcGIS Web AppBuilder | ArcGIS Developers
So, turns out the documentation might not be correct for this aspect. The manifest.json needs also an adjustment at a different level to visualize the style in the builder.We needed to \App\ArcGIS\Portal\apps\webappbuilder\stemapp\themes\themes-manifest-builder.json
If you want to make the app refelct the changes also in the viewer context, you need to mirror changes in the WebAppViewer folder in \ArcGIS\Portal\apps ... It's a bit more complicated compared to the dev edition but it is manageable.
