I have a script which, as part of its logic, takes a map layer from the current map document and gets its source path. Recently it has been returning the wrong path: it returns the path to my default geodatabase instead of the correct path to the layer's data. It used to work fine.
This incorrect behavior occurs with my_layer.workspacePath and with Describe(my_layer).Path. Both of these return the wrong path; if I check the Layer Properties from the Table of Contents in ArcMap I can see the correct path.
Any ideas what might be going wrong? Is anyone else having this issue?
I'm using ArcMap 10.8.0.12790
