Hello everyone,
Basic question : is it possible to update Experience Builder only without updating the whole Entreprise Infrastructure ? We use Entreprise 10.9 but I would like to use the most recent widgets available in Experience Builder (eventually included in 10.9.1) within my organisation. I'm looking for the shortest solution/workaround to achieve this. Thank you in advance.
Arnaud
I think your best bet is to use the Experience Builder Developer version. https://developers.arcgis.com/experience-builder/
You can build an experience using all the latest widgets and options, and even better, you can deploy the experience to a simplified URL on your web server.
Thank you Josh ! It's indeed working (download zip, extract the zip file in IIS, add app ID in config.json, add app URL in portal).
For info : about the authentication issue with classic ArcGIS Experience Builder, it seems to be linked to this part of the documentation. I'm not technical enough to solve it.
URL—Embed a website with a static URL or use the following options to form a dynamic URL:NOTE : Only HTTPS URLs are supported. For security, the embedded app is constrained by the same origin policy. For domains other than *.arcgis.com and *.esri.com , the sandbox attribute is automatically added.
I'm not certain about the authentication, but you can certainly deploy the experience and register it with your portal. Take a look at the documentation to see the particulars. There's an extra step involved, so maybe it's not publishing directly to the Portal.
I've just install it and I can access it on localhost. Is it possible to publish an app from the Developer edition directly to our Portal ? Otherwise, the interest is quite limited for my purpose.
Also, it's now working fine with the Developper edition but with the edition from my Portal, I was not able to embed any of my dashboards (authentification issue). Any ideas ?
