I have a Print widget inside an Expand widget. When viewing on a mobile device the vertical scrollbars are not available regardless of orientation. Is there a css workaround I can use?
Hi @GregoryBologna, I made a quick test app and I can see the vertical scroll bars on a Samsung Galaxy s10. What device are you using? Can you test this app on your mobile device?
https://codepen.io/noash/full/poWxJgJ
Your map has good height, and the widget can grow. If the map container is small, the widget doesn't have scrollbars. https://www.manateepao.com/parcel/?parid=1005600000
