I am attempting to subvert creating an extra Feature Class & manual manipulation of an Excel sheet to create a Street Index table for my maps.
My data consists of a RoadName table, a RoadCenterline fc (line) and a Grid fc (poly). The Roadname and RoadCenterline are related via a unique ID, and I am attempting to use an Attribute Rule in the RoadName table to ask the RoadCenterline fc to intersect with the Grid fc and return the results, concatenated and ordered into the RoadName table field of grid.
The data is housed in the same datastore, and I am using ArcPro 2.8.
Any help or advice would be much appreciated,
Thank you,
Alex
edit: I am not sure if this is possible through Arcade, but worth asking.
Update:
I have changed my methodologies to the following.
Added a Grid field into the Road Centerline with an intersect + array with the following script to Sort & remove duplicates on each line segment:
var arr = [];
var count = 0;
var i = Intersects(FeatureSetByName($datastore,"Grid"), $feature);
for (var f in i){
arr[count] = (f.PAGE);
count += 1;
var results = Distinct(arr);
var results = Sort(results);
return results
With some extra lines, it formats the array into the fields such as below:
P6, Q6
My next and last step is to use a sql statment inside the code to match the foreignkey in the RoadCenterline fc to the primarykey in the MasterRoadName table, with a Relationship class.
I am able to use the following code to get data over,
// first read out the Foreign Key of the Destination Table (Feature Class)
var fcID = $feature.roadnameid
// access the Orgin table (Table)
var tbl = FeatureSetByName($datastore, 'MasterRoadCenterline');
// create a sql expression to query on Primary Key
var sql = "F_roadnameid = '" + fcID + "'";
var related_data = Filter(tbl, sql);
// count the resulting records
var cnt = Count(related_data);
// initiate a variable to hold the result
var arr = [];
var count = 0;
var i = related_data;
for (var f in i){
arr[count] = (f.GRID);
count += 1;
var results = Trim(arr);
var results = Distinct(results);
return results
but end up with
P6, P6, Q6, Q6
This is picking up all three segments and seeing them as Distinct, because
seg1 Grid = P6
seg2 Grid = P6, Q6
seg3 Grid = Q6
I am assuming I need to take the array that is in the RoadCenterline.Grid field, and break that into a string, so there are no values that are Grid= 'P6 , Q6' and then put that back into an array and Distinct & Sort it?
I am not sure if that's the best way or not.
Thank you for anyone looking at this, the help would be appreciated. If I get it to work I will post a detailed workflow.
