Is there a way to create points or lines to depict areas where the speed limit has temporarily changed and have it reflect in the drive times? For example if a portion of a road is under construction and has a temporary reduced speed limit, is there a way for a user to add a point or line to depict the affected area and then the network dataset would pick up and use the reduced speed limit?
