I have a feature service generated from a survey123 form. It has a point service and a related table. On AGOL, I can easily view related records. I want to bring this into arcpro, and essentially join the points to the table so I can retain the lat/long fields and then send this related table off to partners. I try to join the table using ParentGlobalID to the the points GlobalID but they don't match. I'm trying with no luck to figure out which fields link, as this use to work. When I download the geodatabase the relate between the table and the points is not retained.
Any help is appreciated!
