I cannot seem to use f-string and/or string variable in `item_properties` when I want to publish an item (GeoJSON in this case).
Here is what I have:
region = "Gulf of Mexico"
gis = GIS(username=USERNAME, password=PASSWORD)
data_path = "/path/to/data.json"
title = f"Objects in {region}"
item_properties = {"type": "GeoJson",
"title": title,
"tags": "object detection"}
item = gis.content.add(item_properties=item_properties, data=data_path)
publishedCollection = item.publish(file_type='geojson')
The use of a string variable gives me a `KeyError: 'type'` when I attempt to publish the item.
The `KeyError` would go away, however, if I use the following `item_properties`:
"title": "Objects in Gulf of Mexico",
Is this a known issue? I would like to programmatically set the title; is there a way around the inability to use a string variable/f-string?
