It would be great to have an Attribute Rule which updates a feature class based on an intersect of another layer when a value of the intersecting layer is updated. Upon creating and / or updating this can be done using Arcade, however, if an attribute is being populated based off the intersecting shape there is currently no Attribute Rule which automatically updates the intersecting layer(s) when an attribute is changed.
For example, a zone polygon feature class contains an attribute ‘inspector name’. There is a point feature class of poles to be inspected and within this point layer there is an attribute which populates the inspector based on the zone polygon. An attribute rule can be created for create / update so if a point is placed within that zone polygon the name of the inspector would populate the point layer. However, if the inspector of that zone is changed (aka new name), the associated points within that zone do not automatically update.
