NYSDOT and NYS ITS are currently working with AgileAssets on the "LRS Gateway" interface which uses the Roads and Highways REST API to update the LRS network and events in the NYSDOT AgileAssets Enterprise Asset Management (EAM) System.
While completing final testing, we uncovered a problem with the Export Network service that has been documented and reproduced by Esri Tech Support. When running the Roads & Highways’ ExportNetwork GP tool (needed for the interface between AgileAssets and Roads & Highways) at NYSDOT, we noticed the Concurrency output from the tool is different between a File geodatabase and the enterprise geodatabase imported from the same file geodatabase. The file geodatabase’s Concurrency output appears to be correct, whereas the enterprise geodatabase’s Concurrency output is missing records.
