Curious if it is possible to periodically replicate Survey123 data from AGOL to Enterprise. Unsure if distributed collaboration could be used to copy feature classes associated with a survey from AGOL to Enterprise. Even so, it doesn't seem like you could use Survey123 to print reports from Enterprise using the replicated data.
What about publishing the same survey to AGOL as Enterprise, and then periodically copy the feature data (and attachments) from AGOL feature classes to the Enterprise, either using Python API or even better - webhooks. Then managers could use Enterprise to log into Survey123 and publish reports, while users can use AGOL to actually fill out and submit the surveys.
Does anyone have experience with this?
Specifically, this stems from the fact these surveys are very large due to many attachments, and continuing to store them in AGOL is a large hit on credits.
