Hey everyone,
Running in to a peculiar problem with JSAPI 4.21 where the labeling of a sublayer stops the default pop-up from appearing with no console errors, I've not been able to find in the documentation why it occurs either.
Below is the my original new MapImageLayer code where the pop-ups work correctly:
const fieldsView = new MapImageLayer({
portalItem: { // autocasts as esri/portal/PortalItem
portal: "https://lon6p2irsap04.ihsglobal.local/portal/",
title: "Oil & Gas Fields",
listMode: "hide-children",
If I then add the following code between the portalItem and title options above:
sublayers: [{
labelingInfo: [{
labelExpression: "[FIELD_NAME]",
labelPlacement: "always-horizontal",
symbol: {
type: "text", // autocasts as new TextSymbol()
color: "black",
haloSize: 1,
haloColor: "white",
font: {
weight: "bolder"
}], The addition of the above code then seems to cause the pop-up to stop working. Is this working as intended? Why would adding a label remove the default pop-up? I've tried putting the default pop-up back in with: mapview.popup.defaultPopupTemplateEnabled = true but had no success.
I can recreate the problem by cutting the code - viewing the pop-up and then re-pasting the code and see the pop-ups not appear.
Here is the GitHub repo for it: https://github.com/LukeCalladineIHS/vite-edin-knockoff/
Any ideas?
