Hello All,
I have a custom widget which is listening for a Message (e.g. DataSourceFilterChangeMessage). The logic for handling the message is in an implementation of AbstractMessageAction in the src/actions folder. What is the recommend way to pass data captured in theAbstractMessageAction#onExecute method out to the src/runtime/widget.tsx?
Thanks!
--john
I've settled on an approach of publishing the value to the widget's store w/in the Action, e.g.
getAppStore().dispatch(appActions.widgetStatePropChange(this.widgetId, 'queryString', queryString));
and then retrieving it in the widget.tsx via the props.stateProps, e.g.
<h2>{props.stateProps.queryString}</h2>
If anyone has a better suggestion, I'd be glad to hear it.
@john_cartwright_noaa
I am not really sure how you are resolving "props.stateProps.queryString" in your widget. I don't see "stateProps" in the widgets props object.
This is how I am doing it (not saying that this is necessary better).
Sending Widget :
this.props.dispatch(appActions.widgetStatePropChange(this.props.id, 'pSearchData', cTextElements));
Receiving Widget:
interface ExtraProps{ pSearchData: any } .... export default class Widget extends React.PureComponent<AllWidgetProps<IMConfig> & ExtraProps, State>{ static mapExtraStateProps = (state: IMState, ownProps: AllWidgetProps<IMConfig>): ExtraProps => { let wId: string; for (const [key, value] of Object.entries(state.widgetsState)) { if(value.pSearchData){ wId = key; } } return { pSearchData: state.widgetsState[wId]?.pSearchData } } .... //Then else where in the widget code I use the extra prop this.props.pSearchData
