I am trying to use the Experience Builder 1.6 to connect to ArcGIS Enterprise 10.7.1. This seems to hang after I specify the clientID and portal url. Looking at the urls generated in Developer Tools, I can see there is an extra dot following the web adaptor name. (see below)
https://desktop-b184b6v/portal./sharing/rest/community/self?f=json&token=
Has anyone come across this? When I connect to AGOL, there is no issue.
One thing I noticed is that we're both using our machine names for the portal URL. I'm betting that's what's causing the problem.
Did you ever resolve this issue? I'm experiencing the exact same problem, but with ArcGIS Enterprise 10.8.x.
Yes if I remove the '.' in the url, I can get a json response.
From the documentation, EB supports ArcGIS Enterprise 10.6 and later
https://developers.arcgis.com/experience-builder/guide/install-guide/
Have you tried dropping the '.' from the URL? I've not come across this issue myself, but 10.7.1 is quite a ways behind the versions being used in AGOL / EB 1.6, and it would not surprise me if there were some unforeseen compatibility issues.
